Twin Cam V5 Conversion?
(In Topic #209485)
Now, am I best to utilise my existing fusebox (1990 Clipper) and get the loom converted or should I use the fusebox etc from the donor car? (2001 Mk4 Golf).
up to you of course. if the old ce1 loom is in good condition there is no problem tapping the mk4 ecu into it. if the loom is bad I'd be tempted to go for a ce2 fusebox swap, it woudl still need a fair bit of effort but its even more modular than the ce1 fusebox and has a lot more feeds thru the fusebox so dont need as many fly leads seperate from the fb etc
I think i'll down the route of modifying the mk4 loom then to fit my fusebox. I guess a lot can be chopped out of it too?
