Throttle bodies
Hi all
I'm looking for information on running throttle bodies. I want to run a set on a 2.0 bubble block. I was thinking of doing a 1.8t conversion, only I feel it's a little moden for my 76. I already have a bubble block, it's apart apart at the moment because I was doing to run it with injection in my Caddy. But, if I can get it running on a set of bodies it would have the look I want as well as a bit of go! Injection I way to untidy for what I have in mind.
Any advice is much appricated. I did try the search but it's useless.
Cheers good people 👍
I know Jenvey do a kit for the 16v KR as I have a set with a stand alone Emerald ECU on the kr engine I have just taken out of my wifes cabby, I think megas quirt do an ECU too. Not sure if Jenvey  do them for the 8v and I did not think about going that way with the DX or 3A engine because they would be sucking in hot air from above the exhaust manifold.
I am doing the same as you 3A bubble block with a reworked GTI engineering head Audi 2,2 throttle body and WUR. I have a specialist tuner local to me (Autotronix developments) who are going to rework the original Jetronic system.
To be honest the KR was a bit too severe for the wife pottering around hence the change of direction
Last edit: by Pincher
I'm running 45mm blacktop Toyota throttles on my ABF and 16V - both are extensively modified. For motors running less mods we use 43mm silvertop Toyota throttles. We are lucky in that we have a company here in South Africa (Rowland) that produces cast aluminium intake manifolds to mate the throttles to 8V U-Flow and X-Flow and 16V motors. I'm using stand-alone engine management in both cars, running 60-2 pickup and wasted spark and both cars performs really well and despite running big cams are tractable enough to drive in traffic. Main thing when running throttles is to get the right ram tubes - the longer the better, at least 100mm. When I went from 60mm tubes to 100mm tubes on my ABF I picked up 5whp and 12 Nm torque on the Dyno, my 16V race car is running 160mm ram tubes.
Reason the Toyota throttles are so popular here by us, you can pick up a used set for a fifth the price of a set of Jenvey or Precision throttles.
Pic of my ABF engine:
1983 Golf GT 2.1 16V with throttles/1978 Golf LS 2.1 ABF with throttles/2008 Citi Storm 1.4i/2007 Hyundai Getz - my daily
Good information there thanks guys. I'm not too worried about heat from the exhaust, I'll wrap it and probably fit a heat sheild. The 2ltr 8v bubble block I have has had the works done to it, hence why I'm eager to use it. If I was thinking along the lines of losing the 8v in exchange for a 16v, I'd just run the 20v turbo. More power, easy conversion, even cleaner bay and I already have one. I have the full K-jet injection set up for the bubble block, I don't want to run it though because it's big and messy. I'm looking for a clean looking bay, one that will more suit the age of the car. I could run twin webers but I would like to keep some economy lol. I'll look into the silvertop and blacktop bodies, I might be able to get a local guy I know to make me a manifold.  Thanks again for the advice  :thumbs:
could do with one of those manifolds...
I'd quite like to run a set of bodies in the future also but the cost of a set like Jenvey along with everything else is just too much money tbh but the likes of these Toyota bodies does appeal. What are they off Torker? I seen a set for sale that were Toyota 4AGE throttle bodies but I know very little about them? What sort of gains can be had on a fairly standard engine with them all bolted up and mapped?
You get two types, 43mm 'Silvertop' and 45mm "Blacktop' throttles. The black and silver refers to the colour of the tappet cover on the motors the throttles came from. Silvertop 4A-GE up to 1995 and then replaced by upgraded Blacktop 4A-GE motor (in RSi/RXi Corollas)
43mm is better for worked 8V and lightly worked 16V motors, 45mm is better for fully worked 16V motors. As a rule of thumb you pick up about 10 wkw when fitting throttles to a fully worked 16V motor, we are at 1680 meters above sea level so might be more closer to sea level (we call it altitude tax). Fitting throttles to a fairly stock 8V motor is not really recommended, you have to improve the breathing and ability to rev before the motor can fully utilise the throttles, 16V is a different story though.
i have been trying to get my head round ITB's,  IDH etc. i was thinking about converting my abf to throttle bodys, but not sure how to go about it, i know it a simpler convervsion on a KR due to the lack of sensors, from my understanding so far i would have to run a emerald or megasqirt ECU due to the knock sensor and cam sensor in a ABF. am watching a set of direct to head bodys build on GXR 750 throttles on ebay. if any one has a link to a good build thread or some really good reading material so i can get my head round what i would need to do that would be great.
Converting an ABF to throttle bodies is easier than with a KR as the ABF already has many of the items needed for the management. But for either its 'just' a matter of buying Jenvey DTH's, or generic throttle bodies with a suitable inlet manifold (generic throttle bodies share the same mountings as DCOE carbs) then fit your choice of aftermarket management and get it tuned. But it ain't cheap.. the costs add up rapidly.
The same goes for the 2.0 bubble block, except you can't buy DTH's. So buy a set of generic 40 or 45mm throttle bodies, an inlet manifold and a managment system..
Torker what kind of fuel injectors ae you using for 16v and what kind of ECU also?
VW GOLF MK5 / VW GOLF MK1 Owner
