MK 2 dash fitting! Help plz
(In Topic #214913)
Having problems with column.
I've got to the point where the dash sort of fits with a lot of squish but now that's throw up another issue, the MK 2 stalks don't fit on the MK 1 column so the million dollar question is how easy does a MK 2 column fit or can a MK 2 ignition housing (the cast steel housing that holds the ign. barrel and mounting points for the stalks) be fitted to a MK 1 column?
Any help or direction gratefully received.
Pete
1983 MK1 Golf four door 1.8T 20V BAM remapped, MK2 dash and loom, TMI interior. daily.
2014 VW California 5.1 with full Sportline kit, weekend home.
Spoke to VW H and they have the steering lock in stock (£15) so panic over, well over when I work out what plugs in where lol.
Dash is now in and fixed, holes drilled in the bulkhead for the 2 threaded studs on the MK2 dash front.
I cut out a long V from the under side in an upward direction so the ends of the dash could be pushed in and fit.
I'd read in several places that new brackets will be needed but I got away with only 1 in the lower centre area, the 2 main side brackets I bend so they were out of the way while I was juggling/fitting the dash and the when I was happy i removed the air vents and with a brass rod and a big mallet bent them back so the touched the dash, holes drilled through the end panels and screw used into the OE bracket.
Job done.
Oh yeah, the large bracket that holds the steering column has to be cut halfway through and bend inwards to allow the clocks to fit, I'll weld a plate across the cut to put back the strength.
I'm amazed at the level of knowledge you have and the amount of people you help, it is very well received.
I've ended up with MK 2 housing/stalks with the lug cut from the column.
Pete M said
Many Thanks John,
Pete M
Yep John is quite simply amazing but I think I may have an idea why! 👍🏼
When he was born his dear mum put him straight on the bottle.
He was fed on the official VW workshop manuals liquidised until he left school. 😉
He is a walking talking encyclopedia of Golf's and God knows what else.
John was made 'Member of the Year 2013' and award for services to our community, which was more than well deserved and an award that's not given out all that often. He should probably deserve it ever year. 😉
One of the reasons why I mention this is because I was totally surprised at this year's AGM I was awarded this great honor for 2017.
Now I was totally choked up when I received the trophy not only because of my wife being there and the fact that the club really appreciated the effort I put in.
But my first thought was of John aka rubjonny and the fact I've joined an elite club of members which with people like him and Anna aka CabrioAnna although I'm uncomfortable in such company to be honest.
I know I've hijacked your post a bit but I hope a few members read it and like you can really appreciate what we do behind the scenes as we have something special at this club! 😉
I do get a little frustrated when members have had a problem that they can't solve and we rally round sometimes going to great lengths to help them and don't even get a thank you, let alone a 👍🏼in the header of the post! 😕
Right then, never meant to write that much so I'll get off my soap box and back on topic. ☺️👍🏼
I'm pleased things are working out for you and your Mk1. 👍🏼
Sent from my Smartphone 📱
dont put yourself down ,you work hard and it is appreciated by the members, and the award was well deserved
rubjonny said
Thats very kind of you to say
Ah shucks, I'm all embarrassed 😳 now! 😊
Thanks John but it's a team effort as we know, we're all the key elements that makes this Golf Mk1 Club the best in the world year after year. ☺️👍🏼
I've pulled all the plugs from the engine/radiators/fans etc as I was hoping to be able to remove the engine and compartment loom and ship it or take it to someone to sort out but the hole in the rain tray isn't large enough to pass the connectors through so the million dollar question is What do I do now?
As I see it I have a few of options;
1 Take the car to a local lay by and set fire to it and claim on my insurance.
2 Trailer it to someone who will be able to sort it out with all the wiring still in the engine compartment.
3 Cut the main ECU loom in half so I can remove it from the car and sent/take it to someone who will deal with it on a bench.
Last edit: by Pete M
you pull the loom thru the other way silly, it comes out into the engine bay
I'll see if I can upload a picture.
If it still wont go then theres another tab on the other side for the thicker wires, if you pull that out you can carefully pop the pins out with the aid of a pick tool
