Kr vacuum pipes?
(In Topic #212729)
2. no its vacuum. pics specifically of the hose connection you are referring to?
you dont need the warm air flap though, so can bin those lines off if you like
the fitting on the 5th injector housing is either for the ISV or the WUR, there is definitely no coolant feed there. but post some pics
This one I'm unsure
I suppose you could place a Breather cap on it to vent the engine gases, but you would need to plug off the port on the Throttle body. I really don't know how the engine will act, as if I take my dipstick out it creates a vacuum leak and runs sketchy till I put it back in.
the nipple on the 5th injector housing coudl be plumbed into the catch tank same side as the block breather, but you need to make sure the plastic injector inserts are all good as are the seals, plus you need the proper air shrouded injectors with the top hats on. if you put new mercedes brass ones in for example, you'll get a massive air leak past the shrouding system so you should just cap the 5th inj nipple off.
