Flywheel and exhaust queries
(In Topic #217239)
Secondly, I'm upping the steering with anti-roll bars front and rear. Problem is the front ARB will hit the down pipe as mine doesn't have the bend to accommodate it. So my options are either to buy a used 6-bolt gti manifold + downpipe, or level up with a 4-2-1 manifold. Is there any reason why I shouldn't fit something like i the photo? Seems legit to me..?
Hope anyone has the time to give an opinion on this, hopefully it'll help others as well
Early 77 year model Golf. 4-Door
I have a SS Raceland header like the one pictured hanging about waiting for the head work if I ever need to do it… It will go on as it is a CAT delete thing….and since I killed the cat…. You will need to add a flexure piece to it.
Sorry for the wrong picture dang nab pbucket.
Last edit: by Briano1234
My 4 2 1 is fitted to my standard exhaust system via the adapter you may need a different adapter as I belive the standard 1.6 exhaust is smaller diameter compared to the 1.8, it is on my 78 1.6 mk1 Scirocco compared to the 88 1.8 Gti golf.
The manifold runs close to the UJ rubber boot so you will need to alteast wrap the boot or like me the boot and exhaust manifold as well so the gasses escape quicker and to protect the boot.
It is a bit tricky fitted the manifold and don't install the anti roll bar till after the manifold is fitted as you need to remove it to fit.
The 4 2 1 system took a few attempts of moving the standard exhaust system around and twisting etc to stop it banging on the floor or rear beam or heat shield on the gearstick but I got there in the end.
I'm a little surprised your 76 golf does not have the 6 bolt manifold, my 78 Scirocco has one fitted from new so I could just fit a Gti down pipe to go over a front anti roll bar if I fitted one as like you I don't have a anti roll bar.
yes I do have the 6-bolt manifold, but the non-gti version, which has a smaller mounting surface and will not fit the gti-downpipe with the ARB-bend. I know it's smaller because I had it off this winter, and the 6-bolt gti seal I bought was to big to fit.
Anyway then I'll settle with the 4-2-1. I'm gonna have to do the rest of the exhaust as well, since the corrugated pipe won't match the new 4-2-1. Also the previous owner replaced the exhaust sometime in the 80's if he recalled so it's about time :p
I'm not really into the sport exhaust look/sound, so will probably fit the gti version middle and rear silencer, or is that a bad idea on a 1.6 non gti? And Briano, do i need the flexpipe even though the 4-2-1 has a bend for the ARB?
About the flywheel, would a 210 mm fit the 1.6? Don't want to spend serious krone on a 190 mm clutch if I'm fitting a 1.8 engine in a year or two..
Current downpipe. Pardon the disgustingly filthy engine bay.
I did not realise there was a difference in the 6 bolt manifolds, I thought they was all the same with the big block engines, something I’ve learnt today.
For heat shielding I made a wrap of sheet aluminum and bolted it to the down pipe.
Works well.
G60 4-2 manifold and dual down off a mk2 golf. I had my exhaust guys make me a dual down with the old parts.
Next to it is a old rocco, solid dual down…
