Brake up grade
(In Topic #207215)
Speeding is like masturbation, everyone does it ,but it's not something you should record and put on the internet!!
On the MK1 hardly any of the braking effort is done by the rear wheels its nearly all the front discs.
As already said rear discs are more powerful, so just lock up the rear wheels. By modern standards the MK1, even the Cabrio is light weight, you are not trying to stop a 2.5 ton SUV.
Better to make sure the existing system is 100% and if your really do want to upgrade fit bigger discs at front (which will need larger wheels if still on 13 inch) and/or a bigger master cylinder/servo combo.
Last edit: by Early-1800
