Bit of knowledge please.......?
(In Topic #211513)
Rotor Arm / Fuel Pump Wiring
1) Does anyone have a picture or can tell me what position the rotor arm needs to be at if the dizzy cap and HT leads exit out towards the front of the car?
2) I need to connect the bike fuel pump to an ignition live, I've fitted a K-Jet relay to slot 2 but need to locate "E/14" - is this a wire or pin in the back of the fuse box, if so any ideas what colour / where it is!? Any pictures would be brilliant!
Thanks!
'84 MK1 Golf - View topic: Humble Beginnings........... - VW Golf Mk1 Owners Club '99 MK4 Golf
That line is for no 1.
Hope that helps?
but yes, put lead #1 where the rotor arm is pointing when the engien is at TDC, the rest in order 1342 anti-clockwise. some pics in my build thread which may help:
View topic: Project 83 MK1 cabby, several years in the making! - The Mk1 Golf Owners Club
E/14 is pin 14, in the black plug E on the rear wiring harness. If yours is a carby mk1 golf its the only large sized empty pin in plug E. You can buy the pin new, or salvage oen out of a donor loom. Alternatively you can run your pump to the large spade 'N' with an inline fuse if that is easier for you (E14 and N are both pump live, but E/14 is fused and N is not)
is the kjet relay the type without a rev limiter? if so all is well. also how are you going to manage spark advance? if usign a kr ecu you could run the red/yellow wire from the ecu to D/13 on the fusebox (white plgu on the engien loom) this will then allow you to use a 67/80/167 relay which will be controlled by the ecu
I'll be able to sort the rotor arm now thanks
I've literally just found the thread showing the layout of the rear of the fuse box so should now be able to connect to E/14. I'll just look to see how I can connect onto it, getting a new pin to fit into the plug I guess.
Tbh I'm not 100% sure whether the relay has a rev limiter or not.
I am using a KR ECU and also running ZX9R bike carbs (pic below).
So the red/yellow wire is for the fuel pump relay earth trigger that I need to run to pin D/13 which I could connect to the white plug on the engine loom, do you happen to know what colour wire that might be?
The black/yellow wire for the idle switch feed isn't needed, is that right?
Terminals for Special Applications: Polevolt Ltd
farnel also stock them but you need to buy in bulk. as I say can use inline fuse in spade N, thats just a standard 9.5mm spade
do you have the part number for the relay? gsf sell both types. you'll soon find out when you drive it though I guess
D/13 if its there would be pruple/black for a carb loom, or red/yellow for digifant or 16v
idle switch feed is not needed
There wasn't a wire for D/13 but did manage to get a wire to that too. If it's not needed though I'll remove it.
Managed to get the engine cranking (first time in about 8/9 years! lol) along with fuel pressure however forgot to rotate the dizzy 180° so couldn't get her started. Also have a slight fuel leak on one of the chambers of the carbs so need to sort that also then hopefully………might get her started this weekend!?
I'd go with the D/13 trigger if you can, replacement fuel relays are easier to get and cheaper
What I've done is run a wire from pin E/14 on the back of the fuse box straight to the bike pump which I've also grounded. I've also put a relay in slot 2 where there wasn't one before (as it was a carb model originally).
In doing this I do have petrol coming into the carbs.
What your saying is I should run a wire from pin D/13 on the back of the fuse box (and also connected to the red/yellow wire on the kr loom) to the pump and then also ground? Is this safer?
And then a relay in which slot?
Sorry for all the questions and confusion just want to make sure I get this bit right
slot 2 is the fuel pump relay socket yers, which relay you need depends on how you set up your system.
1. use a kjet 8v fuel relay, without limiter. this requires no wiring from the ecu loom to d/13, as its triggered by the rev counter pulse to the fusebox from the coil
2. run the ecu red/yellow wire to D/13, then fit a 67, 80 or 167 fuel relay these are ecu triggered type.
either way you decide to go, the fuel pump wiring you have done to e/14 is correct and sorted
Also thanks for all your help with the wiring side of things as I now finally have this………………..
Big thanks!!!
