1.8t conversion
(In Topic #220186)
Thanks in advance
Kris
Isn't the 02j a mk4 gearbox ? That's what the engine has come out of anyway all a bit of a head breaker to me 😂😂
Last edit: by Cushti
Thanks for your help, I'm sure I'll be asking more questions as time goes on, apologies in advance if they seem stupid 👍🏻😂
And idiot guide would be appreciated if you have time, of things I'll
Have to change and things that go with what
I know about the the engine mounts
I now no aboutvyhe the throttle 😉
What about the gear linkage? I have rods at the mo but if I use the 02j thatvhas a wires correct ? Then there the ancillaries?? It's a mind field 😂
Only if you have time though 👍🏻
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&type=misc&id=modifications-and_2%2F1-8t-conversion-guide_2
Gear linkage is easy, just use all the O2J cables & selector. I bolted the selector from underneath as I lowered the seating position with buckets. Others have run the cables through the bulkhead to bolt the selector down inside.
Your AUQ ecu will need unlocking or the engine won't start, might as well get it remapped at same time
Your first job should be to remove your caddy loom & send it off with the AUQ loom (both parts, ecu & engine loom) to be converted - I recommend rubjonny
Downpipe - rarely they come up for sale, don't know anyone who makes them now, qpeng have stopped doing them. You could buy the K03 flange & fabricate, or cheapest option is probably buy a used decat mk4 downpipe & cut & weld. 3" & you'll have to remove the steering column boot as it'll melt, 2.5" worked for me
Exhaust - I fitted a supersprint 60mm race exhaust with a 2.5” inlet universal backbox. Check out trackslag website for more ideas
Intercooler - merc sprinter or eBay jobbie
Engine - fit 16v tensioner & spacer along with new timing belt kit, thermostat & water pump before fitting into the bay. Junk the pas pump& buy shorter Alt belt
