my 1.1 golf wont idle help please
(In Topic #97661)
but wont idle ive been told its cold start value is this right i have another golf im doing up but dont know to much about them still getting started with them
do i just buy a new 1 ? or can it be fixed
thanks simon
'88 Golf GTI Cabrio….I look like an extra from the village people, but hey I like it.
Seat Leon Cupra R….Amigo espanol rapido
I had this problem the other day and that was what it was.
snoopy-king said
Same on the webber conversion is has a fuel cut off valve which is like a magnetic read valve which as posted above must be connected up to a live feed (I think its + anway ?).
Learn something new each day
so it now idles somtimes but not all the time
its doing my head in trying to get it running right lol
and yes it is a Pierberg carb
thanks for your help and keep it coming i need it lol
if i sit and pump the a/pedal then go to start it it will tick over for about 4 or 5 mins happy then just cut out
what do you think ?
The needle and seat in the float bowl would probably affect running higher up the rev range so it is unlikely that is the problem though.
Check for any residue in the carb float bowl, it is usually a white powder like substance which can cause problems. Could also be a nasty intake leak, so check the rubber mounting gasket the carb is mounted on for splits, any pipes loose, gaskets damaged etc.
hope this helps
