help problems with my 1.1 carb
(In Topic #102778)
it is drivable but wont tick over and also the revs get high and then low and then stall.
help needed
cheers jonny
check the earth from carb to block is intact and good connections,
check idle solenoid working properly
had similar prob with my 1.3 carb
more info in similar posts further down the page
good luck
80 Mandarin Orange Mk1 1.3 Golf Driver
88 Dark Blue Mk2 1.8 8v Golf GTI
here's how i checked mine
should have feed from wiring loom, earthed via strap between top of carb ad fuel pump (make sure clean electrical connections.
check solenoid working by removing - if you place 12v circuit (positive spade, negative threaded housing) it should retract completely, replace if unsure if works as cheap,
check current and voltage from feed wire with multimeter to check not a deterioration of the loom like i had - had to reroute new feed.
if u remove solenoid and rest the metal case in contact with engine whilst wired up, solenoid should retract when ignition turned on, then if i remember correctly should pop in and out in relation to the rpm of the engine
check no air getting in carb/inlet gasket as this will prevent idling - too much wobble in carb ? usually gets worse when engine warms up.
Carb Are you sorted ?
Check in this order
assuming it was all working + set up correctly before !)
1. Rust / particles in system - look at inline fuel filter.
2. Pilot jet poss. blocked (opp. side to the CO + Idle)
Let us know what it was ?
Gordon
