DISTRIBUTOR (1.3 Driver)
(In Topic #117238)
I am lead to believe the dizzy may be acting up, and once I have checked/replaced the cap and rotor arm I think this may confirm this (I haven't actually seen them yet)..
Where can I get hold of a replacement distributor? I have had a look on GSF but they only sell the caps and rotor arms, will I need to ring them directly?
Where else could I find a replacement?
On the subject, if anyone has one knocking about that works so I can use it as a test then that what be awesome, chuck me a PM or something!
It is for a 1.3 Driver
Cheers,
Chris
On the assumption that it will be only one cylinder that's not firing, it will almost certainly NOT be your distributor - if the dizzy was dead or dying, it would fail on all cylinders, or maybe on random firing intervals - there's nothing inside the dizzy that could cause just one cylinder to misfire (apart from one of the four lobes on the points cam being worn down, but this is highly unlikely)
My guess is that the dizzy cap is cracked and a new cap and rotor arm will solve it
it is definately only one cylinder that is not firing, so its probs not the dizzy then.
and eurocarparts didn't seem to have dizzies, just caps for Mk2's. gona have to go for one being broken or something
I got a replacement distributor from probedistributors.com over a year ago.
Couldn't find one anywhere else! Nobody else could suggest antwhere else at the time
Hope this helps, I just remember really suffering in my search for one when mine was internally leaking oil!
Nik
hopefully I won't need one though, will just have to see how things go
thanks again!
Its actually probedistributors.co.uk , (not .com)
Good luck
Nik
