83 Golf Point to Electronic Ignition?
(In Topic #233980)
Change ignition
Hi everyone, i need a idea for my 83 1.3cc golf. Continually i have been using it to long-road trips in eu. But point dies after used long time and breakless drives and i decided to convert it electronic but didnt find enough knowledge on internet. What do you suggest to me this convert process. Thank you'll
I fitted a Accuspark kit to my 1978 Mk1 Scirocco, fairly straightforward to fit the kit, hardest bit was finding a 12v power supply from the fuse box which was still powered when the engine was on the starter motor.
Something like this, check you get the right kit for which make of distributor you have fitted to the car.
https://www.ebay.co.uk/itm/192212426304?epid=2082707261&hash=item2cc0c0de40:g:zh0AAOSwaQdfw-ee
AccuSpark Electronic Ignition
Not sure about delivery cost for you but there is a few other makes out there as well.
Thank you for your answer. Probably this kit will work on my car so but should i need to change the standart coil to electronic coil any suggest?
Not 100% sure for your car but when I changed mine I kept the original coil.
Thanks for everything man
