Front brake binding mystery
(In Topic #78516)
I have a mk1 gti with the 256 mm upgrade and the bigger master cylinder and servo
The front offside brake is binding slightly and causing the wheel to get hot, it stops dragging after its cooled down
the brake pads are obviousley not retracting enough when the pedal is released but its only on that one side
So far I have replaced the flexi hose( they can break down internally and act like a one way valve) no difference
Replaced the master cylinder in case one of the return valves is crapped up -no differnece
replumbed the master cylinder in case got it wrong first time- no difference
fiddled with the linkage to the servo in case its not retracting enough- no difference
now replaced the front caliper in case its siezed ( it was only a couple of thousand miles old but it stands around a lot)- no difference
Any other suggestions or ideas before I take it red faced to my local vw specialist and get "the look"
I could weep with frustration ( and the ?60 worth of bits wasted!)
Chris
Regards Volkswarren
Oh blast deary me ( or other words to that effect)
Ive changes the master cylinder once whats the other problem and why only one side?Cheers
tbh im so annoyed Im tempted to rip the whole lot out and go back to standard but ive jnked the original servo and master cylinder and the litlle block that goes underneath ( damn never throw anything away)
the 256 m brakes are really good but its actually overservoed if i was doing it again id just do the brakes
Be interested to here of anyone else whose had similar problems with this conversion its pretty common
Regards Volkswarren
Matthew
i always have the last laugh
<a href="
http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg<a href="
