Fitting 13" ATS Classics with standard disc brakes.. ?
(In Topic #117236)
I've heard horror stories of these wheels being bought and then fouling on the front brake calipers.. is this true? If so, how can it be overcome.. will I need spacers? How much clearance will I need?
I have standard front discs and calipers, car is a 1983 Driver.
I'm presuming they have no problem going over the rear drums? (Standard again). Also, should I need lengthened wheel bolts with the front spacers, will longer bolts from a Mk4 Polo fit inside the Mk1 hub threads?
Cheers all,
Chris
do you mean without problems?
im buying them second hand mate off a guy who had them on his lupo, and i'm not getting the bolts with them.. just got some longer than standard polo bolts, they should fit in a Mk1 Golf though shouldn't they, aren't all VAG bolts the same thread pattern etc?
The ones you buy new should be the correct offset, so no dramas.
Driver driver.
chudd said
chudd said
I ran these wheels on standard brakes with problems . The wheels supplier will include new bolts .
ops: sorry forgot the NO !
hahaha phew, thats what i was hoping you meant lol
brucieboy said
i have 13x7's on the fronts and 8's on the rear, the fronts foul the brakes and require 100mm HUBCENTRIC spacers and long bolts and thats the only problem i had with them!
100mm?
do you mean 10mm?
10cm seems an awful lot.. are the calipers even that wide?!
nice one mate!
CWA said
100mm?
do you mean 10mm?
oh crap! soz mate lol, yeah 10mm spacers not 100mm or 3mm 10mm clears the calipers by 2mm (bit close) but its ok, :mrgreen:
