1982. C =>GTI.
(In Topic #218758)
1982. C =>GTI.
It seems to be alive. However there was some welding operations with rear fenders and a corner of rear skirt. But at least it has no visible rust. Good base for the further action I think.RichardHall said
That looks a really solid body shell from the photos.
Last edit: by 1982_mk1
1982. C =>GTI.
We installed 280 mm front disks on VW Passat 35i calipers using some kind of adapters.
Rear drum brakes were improved too. We used bigger diameter brake cylinder from the same VW Passat 35i.
After that we installed 25,4 mm VW T4 master brake cylinder.
We needed 15" rims to wear on 280 mm front brakes so VW Passat 35i G60 Steelies we're bought.
1982. C =>GTI.
