Mk1 Cab Chewit
(In Topic #207232)
1.4 4 speed petrol manual GLS
Registered on the road in 19/02/1982
Work Done:
old engine removed (1.8 not original)
engine bay rust sorted, seem welded, painted
New nuts, bolts & washers for engine install
Pd diesel engine mk4 engine 1.9tdi, 5speedbox
Custom Made Down pipe
Solid Flywheel conversion & new clutch
ce2 Fusebox, mk4&mk1 loom modded
Mk4 20vt motor mounts (poly bushed)
intercooler, pipes & water bottle
radiator
Fuel system (tank, pump, filter & lines)(mk2 golf GTI setup)
Brendon drilled and grooved discs
new battery re-located to the boot
Front brakes setup (mk2 Golf 16v setup)
New brake lines
GTI Cab 100mm Cups
Corrode G60 Pedal Box, Hydraulic Clutch, Cable Accelerator DBW)
Underneath cleaned up and undersealed
Refurbished and powder coated BBS RA'S 15'' with new tyres
Debagged Chrill
Smoked Front Indicators
Smoked Front & Rear Lights
Work ToDo:
New carpet
New roof
Seats cleaned up
then replace things for better condition/new
So the pd115 AJM engine and 5 speed box to start with, with the scope of increasing it to a pd130 and 6speed box
So thats how i bought it……
Last edit: by MatieusCab83
Front Head Lights
Rear Brake Lights
Front Bumper Indicators
Inner Door Handles
Inner Window Winders
Inner Tweeters
Wheels
Grill
Engine came out
Brakes came out (incl servo)
pedal box out
wishbones out
most of this was sold
Then came the G60 pedal box
Then Mk2 GTI Fuel & Brake Setup & Servo
Then the new alloys (with near new tyres)
New Front Lights (clear smoked)
New Rear Lights (clear Smoked)
New Indicators (clear smoked)
New Inner Door Handles (chrome)
new wish bones
green stuff brake pads
brembo brakes
new brake lines
Service kit
Gas Struts (chrome)
new rear brake rebuild
wiring upgrade for headlights
h4 bulbs
Bulk head welded
engine bay welding
stitch/seam welded bay
shot of black paint
Interior
Boot - taco, downpipe, shafts, airbox
pedals
Brembos behind old alloys
Looking busy and sorry
wheels on mock the grill
front alloys was stubborn
figuring out where to mount washer bootle &
the expansion tank
Figuring air filter and intercooler
ready to go away for the final time
Ready to go
Wiring finishing
Accelerator Mounting
Expansion Tank Mounting
Washer Bottle Mounting
Air Filter Connected & Mounting
Intercooler installed and routed
speedo cable installed
Brakes bled
Then testing
Chrome Mirrors
Chrome Side Strips
New carpet
New Main Dash layout
Double Din Stero
Gauges
Seats, door cards and parcel shelf
roof - Black or White?
Respray
Passengers Breaks & Wishbones
Under side
She go's again…For more work
My conversion is a little more complicated than yours as I have A/A and want to keep it. Also want power sterling and have changed all……….so I need to make space in the front for all 3 radiators: water, condenser and intercooler.
Breaks: Want abs, arl with that power so all going to change. Have bought big 4 piston front calipers, rear disk conversion, new lines, sensors, wiring, control unit….. a big job.
New complete respray and chrome bumpers.
ARB from K&W new as well, as it did not have them originally and wanted them, and then comes my question: Which suspension coil overs are you planning in yours?, as you do not mention anything about it.
Any suggestions and recommendations from your swap will be appreciated.
Regards.
gonzalogamir said
Hi, my name is Gonzalo, from Spain, living between Madrid and London, I found you here in this web, as I am now in the middle of your same past engine conversion. My last engine was a 1.9 diesel non turbo and had it for many years and wanted a change so I decided to go for a ARL engine diesel, but plan to remap it and get a little more, probably 180. Want to use it a lot, as a daily car, and diesel is still cheap in Spain. Not like in the UK.
Regards.
ill be honest getting the engine in, running correctly gearbox, speedo wiring loom, gearbox & exhaust first and then its suspension new roof paint interior
So last time i posted the Chewit went across to a guy to be finished ''of''
Engine re-positioned
Rear engine mount changed
Intercooler & Pipework installed
Speedo Cable
Clutch Pipe
brakes filled and bled
fuel filter and pump
driveshafts bolted up
Exhaust (flexi part, down pipe & fitted)
battery relocated to the boot
fuel tank flushed
a lot of playing around with wiring
