Mellow Yellow 3.2ltr 24v Conversion
(In Topic #205529)
To make the conversion easier I've ordered a mount kit from eurowise. They have a new kit which is specifically for the 24v V6 engines that's not in their store which mounts better than the VR6 version. I also ordered the R32 stainless downpipe for the Mk1 which is also not listed.
Now I must admit there is very little information on this conversion and everybody I've contacted has failed to respond.
The wiring seems a problem as I want to keep stock clocks, I've already been in contact with rubjonny If anyone can provide any information on the conversion or knows anyone that had done it please let me know
Last edit: by Rich.
I think the r32 is the best looking engine you can put in a mk1 golf
There's a chap called mk1 James on ed38, and I'm sure he posts on here too, who has done a stunning r32 conversion, perhaps he could help?
Good luck anyway, can't wait to see it fitted.
Matt
pazwaa said
Always up for a challenge,
Matt
I've tried to contact him twice but no response. He is local to me as well!
I will need all the luck I can get cheers
pazwaa said
Have you tried contacting him through ed38? He's posted on there recently.
No I will give that a try
I had a mk4 R32 and would have another in a heart beat such a good engine!
Don't forget that heavy duty suspension for the extra weight of that R32
And V5 gearbox:
At the weekend I can get the engine and gearbox on stands and start the clean up process
Last edit: by Rich.
Will you be needing to wrapping it to protect the steering rack boot etc?
Also what size driveshafts have you gone for?
I assumed your current ones where 100mm and 100mm gearbox cv cups? Are the new drive shafts 108mm ?
Lhasa2008 said
That manifold looks tasty
Not sure yet on the fitment, Eurowise said it should fit well. I have loads of heat wrap on the UJ boot and will heat proof the bulk head as you could feel the heat through the bulk head with the g60.
As for driveshafts they came with the eurowise kit so not sure yet. I have a gearbox with 100mm cups on spare so can swap them over
The Yellow Peril R32
So is there a difference between the current and new driveshafts ?
L
Umi7 said
Look nice my plan was put r32 is well this year but too busy on work no spear time if you dont mind how much is cost the kit and manifold i may ordered get early ready for action
Cost a pretty penny, if you speak to them you get a better shipping rate and its cheaper overall
They also powder coat everything as standard so no additional fee.
L
I love it your asking me all these questions when i'm clutching at straws trying to get answers for it ha ha .
I'm not really sure as my previous driveshafts went with the conversion.
The passenger side does look shorter and I would imagine the v6 is wider so I reckon they are different lengths. I can measure them if you're interested
Doh! I have now realised I have asked such a stupid question
Obviously the two extra cylinders is going to make a difference to the position of the gearbox and hence the length of the driveshafts!!!
Things I have left: water pumps (main and aux), timing chain kit ,vr6 fly wheel and clutch and good to go I'm sure there are gaskets and bolts /nuts I will need.
I will measure up the front to see what radiator and fans I can fit.
Last edit: by Rich.
Does anyone know if these are necessary when not fitting power steering?
Are there clearance issues with the alternator as it too low as stock and the replacement bracket lifts it up under the inlet?
I've seen other Mk1 R32 owners are using this pulley 022 145 299 d but not sure whether the big aux bracket is required?
Rich
