Lockdown time to work on my GTi
(In Topic #223883)
Sharing ideas
This was engine before start of work
Powder coating of rocker head and rad cover…. alternator disassembly, paint and reassembly…..starter motor resprayed and dizzy cleaned up.
Next steps are to wire brush dirty areas of engine, degrease as required, replace K Jet airbox gasket, paint the brake servo and install rad card…… received most of the parts….found a good supplier from Germany, good price providing you purchase several parts as shipping can be costly.
Also will be sourcing the decals for finishing touches.
Last edit: by BRINZ
Also appreciate any pics of cleaned DX engines to motivate me more and make me jealous.
Cheers!
Did you spray your alternator like I did? Or that wire brush cleaning?
Really like the blue colour……I'm hoping to have my car ready for any future meets…..after the engine cleaning……just have the P Slots to get refurbished.
BRINZ said
Lovely cars you have
I used a brass wire brush on a Drill to clean it after I took all the grease off of it, then a Brass tooth Brush…. I then painted it….GOLD.
BRINZ said
Are the scuttle trays usually longer in length in these models? My tin top appears to be much shorter.
An a/c equipped cars the rain diverter, or Scuttle tray cover as you call it is about 6 inches longer for the Ac Plenum and Keeping water to a minimum. I have found that re-directing the Vacuum and windscreen hoses out of the rain drains, and via the Grommet using hard lines the best thing you can do. I changed over to Black Silicone hose and changed out the gold Balls for a really big check valve to get the over hanging stuff out of my way.
Changed over to black, and then removed teh tiny check valve for the bigger one above.
I finally re-ran the Windscreen hose on my Cabriolets, in to the hood hole, I used a small brass butt-to-butt where it was being pinched by the scuttle.
Worked really well Kept the Scuttle drain clean and made the bay a little bit less confused.
The Big check valve is from a US Chrysler Mini-Van.
I used VHT, and have run the engine a few times to cure the paint….
As far as wheels the best thing I did was to Strip the clear and color off my teardrops and then using sandy-type papers then polish, that is 400-3000 wet/dry polish them… sad was that it took about 3 hours per wheel to polish….
Keeping then up is that about every other year I scrub them with an SOS pad, then Polish with Brasso…
Whip
/wip/
Noun - Car
/wip/
Noun - Car
btw - the starters are heavier than they look.
J
Whip
/wip/
Noun - Car
/wip/
Noun - Car
BRINZ said
Yes easy to remove….. Allen head bolts and nut on otherside of bracket….. Disconnect battery before doing any work and be very careful when removing as it is heavy…… Keep your head clear at all times……
Noted
Whip
/wip/
Noun - Car
/wip/
Noun - Car
Makes a big difference.
Sadly the little part no plaque on mine is really scruffy…
Can't wait to clamp them on……
Have owned :-
Mk1, Mk2, Mk3, Mk4
Bugs, Buses, Type 3
Porsche 911T '71
Mk1, Mk2, Mk3, Mk4
Bugs, Buses, Type 3
Porsche 911T '71
