Just another r32 conversion.....
(In Topic #219255)
Thought i'd start a project thread for my winter r32 build. Car is an 83' Gti tin top in mars red. I bought it as an unfinished, non-running project around 3 years ago, i put all the glass back in to keep it weather tight, washed it then parked it up and haven't really done a lot to it since, until now.
I've always loved the sound of the r32 v6 engine but not a massive fan of the mk4 so when one came up locally that was mechanically sound but with tatty bodywork for a fairly cheap price, i basically bit his arm off as i knew i wanted to carry out an engine transplant to my mk1. I stripped the mk4 down, sold everything i didn't need & nearly broke even, result!
Anyway here are some pictures to start off, i'll keep this updated as the build progresses over the coming months.
Then started removing everything else that was left behind, might be in the way or distastefuly added over the years. Including but not limited to crappy wiring repairs, single wiper conversion that leaks rain onto fuse box, badly replaced brake lines and soon to be gone 90's looking mirrors.
Only found a little crusty bit on the scuttle so far but I've got some work to do on the scuttle anyway when I put it back to twin wiper set up.
Heater matrix has been leaking too by the looks of it
Last edit: by Super_ted
squirrelofdoom said
We should definitely have a "Red R32s" meet up when you're done
Keen! Hope you don't mind a long wait though.
borednow said
I like the mirrors
She looks like a good solid example. Nice work so far.
Ian
They'll be available very shortly if interested? I can't wait to remove them.
Sure you'll be done soon haha. Where you based? I'd be happy to lend a hand
Very kind offer mate, will bear it in mind when I'm stuck. I'm based in Oxford.
Cracked on with stripping the parts I don't need from the engine last night.
Removed the gearbox which is now sold and on route to Germany somewhere.
Before
After
Looks to have had a new alternator recently so that's a bonus.
Super_ted said
Rear strip down, clutch and flywheel removed
Looking good
Like wise if you need any advice give me a shout, but saying that you will probably be further along by the time I get started again
Rich. said
Looking good
Thanks. Yours was one of the threads I've been following.
Managed a couple more hours on it this morning. Got it on the ramp and finally managed to get the driveshaft nuts off!
I then ran out of time. Battery tray is next.
So with the current lockdown situation I thought I should probably try and do something with this so stay tuned for some updates!
Super_ted said
15 months! Where does the time go??
Get some photos up!
