Andys Sportline
(In Topic #218681)
So I got My sportline on 24th June. Took me 18 months to find one because A. I wanted black which seem impossible to find these days, and B. wanted low miles. Over that period only 3 came up for sale, a really nice one in Scotland for £11k which had 82000 on it, and then a non runner in Barnsley that went for £4650 with 120,000 on it. Couldnt afford the Scotland one as it wasnt perfect in my eyes and wanted 'good' money for it despite work to be done. Went to view the one in Barnsley and not only was it a none runner it had been sat outside for about 5 yrs and was in a terrible state……
………….So that brought me on to car number 3 which felt like it had been waiting for me, 1992 model with 86,000 on the clock. Had spent most of its life in france so the most solid car I have ever come across and last owner had done £2k worth of work in the last 12 months including fuel tank, filler neck, brakes all round, pumps, belt ect…. I bought the car sight unseen really as put a decent deposit down to secure it, when I turned up it was what I expected from a 'running condition' as in all mechanically sound however body work looked like it had never seen a polisher in its life and that someone had washed it with stones, also interior needed the usual refinements. Mrs wasnt overly happy but bought it anyway as you cant be picky when so rare and mileage/ age and everything else was right.
Long list of work to do but first up before and after picks of body
Last edit: by ajc1984
Suspension - feels like its running on none so assume its a bit worn out, plus it needs a bit of a drop. Debating what route to go at moment, coilovers or eibach/shocks
9 inch servo upgrade as brakes are not inspiring got all the bits just waiting until summer over and then I can get it parked up and sorted over winter.
New carpet bought just needs fitting
Seats want a wet vac and 2 small cig burns sorting out
Door tops 'leather/vinyl bit' needs replacing as cracked from sun - bought just need fitting
Full deep pile carpet set - bespoke red stitching
Also going for the red clock surround and vents like the euro spec cars to match new wheel below….. most to follow in coming days
General replacement of tired looking parts on the list for winter!!
However couldnt help myself, bought a steering wheel end sent it to royal steering wheels for re-trimming, looks and feels amazing.
Advise on suspension would be helpful as I dont want a harsh ride but I think front sits too high and rear just about right (35mm differance between front a rear) so worried if I use a set spring like eibach it might not give me the same stance as coilovers where I can get it perfect… looking at AP coilovers any good?
Also do you think the rear wheels need a 15mm spacer to bring them out of the arch slightly?
Yes. Yes. Yes.
This is awesome!
Shame about the rad but at least it was only on the way to work and nowhere important
I'd highly recommend Vogtland Coilovers ( http://lowerks.com/vogtland-coilovers-vw-golf-i-typ-17-74-93.html ) this is the cheapest I could find them for as they normally seem to be up in the £500 - £600 price range.
I had NJT coils on before (at around £300) and the difference is like night and day. My Bro in Law uses the Bilstein shock / spring kit at a drop of about 30mm and they seem to ride about the same tbh. If anything I'd say my coils are slightly more forgiving and less harsh!
Steering wheel looks great too. Any links to the company you used?
Ian
Will have to look in to the springs as not heard of that brand before.
Royalsteeringwheels.com is where I got the wheel done having read through loads of forums supposed to be one of the best around and I have to say mines come out great as hes matched the grain/texture of the leather to the plastic centre horn push very well and colour also.
15inch diameter.
6 inch wide
Offset ET35.
I see you're running 185/55 tyres from the pictures. Assuming you're running the same size all around what I'd be tempted to do is:
Remove the tyres from the back and replace with a 195/55 (you can keep them and then get them put on the front when the original fronts wear out )
https://www.ebay.co.uk/itm/BF-Goodrich-Grip-195-55-R15-TYRE-ONLY/401489183772?hash=item5d7a9ec41c:g:kzQAAOSwXEdaeY6a
This will move the sidewall 5mm closer to the arch. It's also a bit higher on the sidewall meaning that the car will then also sit 5mm higher at the back if you suspension is all ok and the car is normally weighted ( I know you've currently got problems with the suspension!) It also gives it a slightly nose down look and beefs up the view from the back a bit.
I'd then go for a 15mm spacer probably as ideally spacers should be kept as narrow as possible as the wider you go the more load you put on the bearing etc and the more wear you're going to get.
Overall this should take the edge of the sidewall out by 20mm.
Have a measure and see if 20mm is about right.
Enjoy
Ian
Latest job…. after someone drilling an alarm LED on the switch column but in the most random place (looked like they just closed their eyes and drilled wherever the drill landed first) I was trying to get a replacement. Either they were all drilled for alarms/imobilisors or there was an undrilled one on ebay for £100 which was mad. So I set about restoring mine first. Filled hole with apoxy glue, added light filler over top… then sanded it all right back and then to get finish back to original I coated it in some textured bumper paint. Im really happy with the results looks better than new as blanking switches now also match and colour is a good match.
Jobs over next few weeks:
Red stitched gear gaitor
New GTI gear knob
Red stitched hand brake handle cover
Red stitched hand brake plastic cover trim piece
New seat gliders to fit once new carpet installed
All need to be glued and trimmed to get them.perfect so should be fun!!
Im not a fan of the red on the dash trim but you have made a really good job of it.
Im the same as others have mentioned, I have 15mm spacers on the back as well.
Although I like all Mk1 golf / jetta / caddys the clippers are probably my least favourite but yours is looking really good
Current rides:
Pulled old carpet out was hoping to get away with keeping the underlay but it was well past its best and flat. Got some top grade airwalk solid rubber underlay with 64db sound proofing to go in, 24mm thick so is a match for the original and should stop the carpet pulling away at the doors, although im also going to glue as well as clip it to be 100% sure
Current rides:
