(In Topic #215028)
Last edit: by Old Duffer
As I'm not in the U.K I'm not going to be a great deal of help but fear not, I'm sure someone on here will either have a good spare or can point you in the right direction. 😉
So here's a bump to the top of the list! 👍🏼
Showing out of stock but you now have the part number.. Maybe drop them an e-mail to find out when they are getting them back in stock?
http://www.classic-vw.co.uk/mk1-golf-cabriolet-gti-fuel-swirl-pot-533201151a-4981-p.asp
Expensive for a plastic box but that is the price of them…
You may be able get them from Germany if in a hurry?
https://www.werk34.de/
Ray
Check the fuel filler neck and fuel filters are best replaced every couple of years or 20,000 miles.
Not sure about by passing the swirl pot??
With the new filler neck it's worth painting it with plenty of stone chip paint and waxoyl it once in place as it has a lot of mud, stones etc thrown at it. I do clean mine before and after the winter as the mud does like to sit on top of it and that is what rusts it away.
Don't use hammerte paint on it as it's rubbish as it's to hard and chips off easily.
I know the cabriolet filler necks are expensive to buy so that is why I recommended some good quality paint so they last a lot longer. I've painted my new filler neck fitted last year with epoxy mastic and then a couple of coats of stone chip paint then lots of waxoyl. My car is a daily and gets used all year round.
http://www.rust.co.uk/em-121-epoxy-rust-proofing-chassis-paint/c28117/
Get a new rubber hose which joins the filler neck to the tank and 2 new jubilee clips as the old ones usually rust and the rubber hose goes rock hard and is tricky to reuse.
http://www.ebay.co.uk/itm/VW-GOLF-MK1-GTI-CABRIOLET-SCIROCCO-MK1-MK2-FUEL-FILLER-NECK-HOSE-N90119601-A738-/191452129239?fits=Model%3AGolf&epid=0&hash=item2c936fa7d7:g:~DIAAOSwD0lUkVOy
If if you can see the pictures in my thread you can see my filler neck and what I’ve done to it?
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-mk1-golfs_2%2Fmy-daily-drive-1988-gti&kfs79=180
Last edit: by mark1gls
hopefully you got sorted out now.
How's the progress going now?
