My first cabby, here comes the summer!!!
(In Topic #96832)
The cars got a manual choke, this is going to get some getting used to…..i tried to start her this morning and it took some time to get done, but once it was up and running, it turns over nicely. Is this a common problem with the mark 1? Due to my job, i have to leave early and i'm not really wanting to be waking the neighbours up every day with the sound of a car trying start. Are there any tips or anything i can do to ensure the engine starts and turns over first time without sounding like i've bought a bag of nails?
Second, is the mark 1 known for its tappets going? When i picked the car up yesterday, first time it started there was a tappet knocking sound. as the car warmed up, this started to go and on the test drive, it sounded great. I did 180 miles to drive back home yesterday and though the engine was responsive and had no problems, there was still the tapping sound. When i started it this morning, she turned over fine and there wasn't too much of a tapping, but then you could start to hear it. it doesnt sound too major, but it doesnt sound too good either. Anything i can do to stop this?
As i said, you get what you pay for, so i'm not going to complain too much. Its a gorgous looking car and the drive back yesterday was one to remember. looking forward to making this a project to get it up and running at its best, i know it'll take time and mney, but any tips or advice to help me on my way would be much appreciated. Cheers!!!!
Make sure the car is in neutral, then fully depress the accelerator once (this doesn't actuate the choke 'cos it's a manual, but it makes sure you've got a decent squirt of petrol to start the engine with). Pull the choke knob fully out. Depress the clutch pedal, then turn the ignition on and try and start the engine. It should fire up first time if all your ignition components are in good order. Then let it rev at around 2000rpm for about 30 seconds, then let the choke in a bit to around 1500rpm. Once you've been on the road for a while and the temp guage needle starts to rise, you should be able to push the choke all the way in, which you should do as early as you can 'cos an over-rich mixture is bad for the engine and for fuel consumption!
If you are trying to start the car again later in the day after leaving it parked up for a while, I always just pull the choke out a little bit from wherever it was when I parked it up; with practice you can judge the correct amount of choke in this circumstance. Alternatively you can start with a touch of throttle and no choke, and then adjust the choke to the correct idle once you're up and running. If you've only left the car for a few minutes, then you can start it just by turning the key.
Hope this helps!!
btw- yes, noisy tappets are a quirk of all old VWs, but are usually nothing to worry about. I'd leave it alone if I were you!
Re: My first cabby, here comes the summer!!!
pegasus797 said
a great looking F plate karman cabby, got it from a guy in london on ebay for an absoloute steal, ?360!
?360 Bargain!!! Get some pics up mate!
where abouts you from?
Welcome to the site by the way!!
<a href="Pictures by jonnymk1 - Photobucket"><img src="http://i264.photobucket.com/albums/ii188/jonnymk1/illiza8-3.jpg" border="0" alt="Photobucket"></a>
Web Team
And welcome to the site.
'89 Black 1.8carb Cabriolet
i too have memories of changing the fuel filter every 2 weeks
newrez said
My 89 karman cabby has an automatic choke and its not a gti
Yeah, it was only the small block engines that came with a manual choke from the factory. My GX would have had an automatic choke on the Pierburg 1b3 carb, but as these so often prove troublesome, it has been replaced with a Weber with manual choke. It took me a bit of getting used to - even my 1971 Beetle has an automatic choke!
Btw if the autochoke on your Pierburg 2E2 isn't playing up yet, it probably soon will!
I'll keep you posted and will probably be on the site a few times more to ask questions and bend your ears. Thanks for being friendly and for the advice!!
Simon
Just got myself a GTi Convertible - needs some work doing to it, but cant wait to get it done and drive it round in the summer, get such a buzz and big grin when driving it.
Hope all goes well! Get some pics up!! If you get to know of any good places to get parts etc, let me know!
