Golf GTi 1.8 1990 Great condition Garaged 20years plus
(In Topic #230669)
car on 135k miles
loads of history owned once by Barings bank. Also was Black with a grey hood now Corrado blue.
jobs completed so far are:-
- Alarm immobiliser removal
- All fuses replaced aligned with recommended ampage
- Fixed a draining battery turned out to be retro fitted electric windows off 12v permanent now on ignition
- Door pins replaced and drivers door aligned
- 3 point rear seat belts fitted
- New carpet mats
- Clutch release bearing and cap replaced
- Clutch cable grommet guide and fitting kit
- Boot trim secured with A4 binders
- 2 month old cracked tyre replaced under warranty and leaking tyre re sealed
- Misted full beer lamp on the inside cleared
- Stereo wired from 12v to ignition
- Cigarette burn fixed on chair professionally
- A few rattles and squeaks resolves
Last edit: by Pcundy
Car Golf 1.8 1990 GTi Cabriolet in Corrado Blue
(Was Black with Grey hood) 135k miles. Original number plates and dealer rear window sticker.
Owned by Barings Bank at one point. 5 Owners from new. Off the road 2010-2020
new mats
Item purchased
https://www.ebay.co.uk/itm/172244466129
Replaced with
Regional Host NE
bit glass cleaner and a microfibre coth well thats
how i did mine
How did you find this kit for fitting and durability/safety? Considering getting it for my Cab as I need it for child car seats.Pcundy said
Crazyquiffs 3 point belts that came with the car now fitted
Early-1800 said
How did you clean the headlights?
There are a couple of metal tabs at the back of the headlight, prise these open. Ideally remove the headlight to do (I didnt). Then find a soft cloth to put on a stick or screwdriver. Then I just used window cleaner
http://www.heritagepartscentre.com/uk/171513033p-rear-shock-absorber-oil-filled.html?gclid=CjwKCAiAoOz-BRBdEiwAyuvA63CM3e1NbR0DZtW2zuAtvv5V5xaPqpmEL4s9I0ho9aMfOhB-fcGj-hoCd7gQAvD_BwE
Clean up in the boot and space saver tyre pressure check to the recommended 60 psi
Plastic parts for Seat runners 2x of each parts 171 881 213 B & 191 881 213
Easy job Phillips screw for runner cover behind front seats to be taken off. Then bolts front Centre of front seats. New parts fitted greased and refitted.
