GTi cabby rear ARB outer bushes
Hi
Thought would share some info and maybe use to someone else in future
Did read through older threads on this and mentioned using big hose clip or vice grips, I used both as when using just grips and tapping on tapered clip the grips can spring off and scare the ^^^^ out of you.
Also the threads had link to older thread which was empty.
Key is slow and steady - if tapered clip doesn't go on too easy start again - my first go there must have been a burr or something as clip jammed and scored big groove on inside edge and had to be filed flat before re-use.
Photos probably explain better - sorry, showing in reverse order!
20170505_171022.jpg 20170505_170259.jpg 20170505_170141.jpg 20170505_170108.jpg Hi
