Golf C Mk1
(In Topic #222588)
Starting Problem
I am new to the club so hi to everyone on here.
I have a 1982 Mk1 Golf C 1.1 which i am restoring with and for my son.The engine runs sweet but is difficult to start,the manual choke operates but the only way i can get it to run is by taking the air box off and putting my hand over the top of the carb.Once started it runs great and will start again,however if it is left for a while it wont start again unless i put my hand over the carb again.
Could it be the fuel is syphoning back and is it the carb or the mechanical fuel pump,although the pump looks new?
Many thanks for any ideas or advice.
Sean and Paddy
As I don't know if you have a fuel leak issue but I would
One way to half arssse diagnose for fuel syphoning is to slightly loosen the fuel cap to allow it to vent so the fuel can't be Vacuum sucked back into the tank…
I would also check to see if there is fuel in the carb (be careful as you may need to replace the gasket if it leaks, you can source through eBay). Also check the carb jets…..smallest (pin sized) amount of blockage can cause issues. I experienced this with my 1.3 C (GF).
Also check air fuel mixture setting is correct
I have found that the rubber pipe to the card was perished so i have replaced it which has helped.I also noticed a leak coming from the petrol pipe somewhere in front of the rear wheelarch so i will have to get it on the ramps and take a look.Hopefully it is the petrol syphoning back because of these two things.
Thanks very much for your responses.
