Samco hoses
(In Topic #88666)
Samco hoses
Hi all, i wanna buy a set of blue samco hoses for my 92 mk1 gti 1800 DX cabriolet, do i just order a set of mk1 1800 and will they fit? as i'm not quite sure!! also gonna change water pump at same time, where is best place to get one seen em on fleabay for about ?30 posted!
Phil
Pretty sure the 1992 cabby has an oil-water cooler, which will mean it has different hoses than a 1983 hatchback. You'd have to make sure of this.
water pump
MP
go go samco
PLUS THEY LOOK LOADS BETTER IN A CLEANED BAY
hello!
fitted 3 of the 5 samco yesterday.
the 2 i cldnt get to fit were the the Y shaped on comin off the water pump [ be easier when pump is off/replaced.
and a straight one i couldnt see where it went anyone help ?
there is a major hose that is not in the coolant kit as quoted above.
Loving any chrome or carbon bits...
I've just put a set on my mk1. I'll post a pic.
the little straight one goes from the water pump to the metal water pipe… And she's a tight fit. Spot of antifreeze will be needed.
92 Fashion Line cabby (New Girlfriend )
89 Black Clipper Auto (Lost)
83 Black GTI Engineering Resto - (Minty!)
05 PD Passat daily driver (unbreakable)
the main pipe from the water pump to the head was in the location for a 1.8 head so doesnt fit
the small straight pipe from the pump to the metal pipe has far too small a diameter to fit even when i had the pump off the car so doesnt fit
the y piece bit doesnt seem to be able to go anywhere
so 80 odd quid for 2 hoses i can use and a 7 week wait from teh factory…
ill never buy samco hoses again
g40'd ratter
<div><embed type="application/x-shockwave-flash" wmode="transparent" src="http://w139.photobucket.com/pbwidget.swf?pbwurl=http://w139.photobucket.com/albums/q312/Forgeman/75e604af.pbw" height="120"
