MK1 Golf Brake Upgrade Information Needed
(In Topic #83171)
Any help would be great, as the roads are gettin very wet.
Thanks in Advance
Have a good read through this
HTH
Rich
Also the servo/master would i need to put one in from the gti also? How difficult is it to swap a 16v servo (as theres one on ebay going). A mate told me the brake lines would need to be redone? Can any 1 shed some light on that.
Thanks.
(sorry i'm a novice to mechanical aspects of a car).
You should be able to buy the Passat servo and m/c, and the discs and pads straight from GSF.
For the calipers and carriers, I'd go for second hand items. Try Crazyquiff on here…
HTH
Rich
Passat 16V M/Cs dont all have 4 outlets, mine only had 3.
This will make more difference than upgrading to gti discs and pads, however as mentioned in previous post the master cylinder and servo is the best upgrade first, and when done with the pedal modification will result in an exceptional difference.
I know this because I studied automotive engineering at uni for four years, some people will say that it will make no difference. I tell you now that they are wrong and probably just repeating what they have heard!!
Try it you might like it!!
Rebuilding Again…
