help with flywheel on an abf please
(In Topic #90372)
My 020 gearbox has a small input shaft, and i'm trying to mate it to a 2.0 abf.
Problem 1: flywheel on the abf is too large, what are my choices, are there any smaller 16v ones that will fit or will an 8v one fit and will it affect how smooth the engine is?
once i know this i can then start worrying about the clutch.
Thanks in advance.
Any further help would be appreciated.
flywheel.
RobC said
I used the lightened flywheel (and gearbox)from my old 1900 8v when I put in my ABF, the engine now picks up really well. If you've got the flywheel off anyway defintely try to get it lightened
as they said in the post a flywheel from 8V or 16V with 020 will fit.
but your gearbox will probably not hold for so long with the 16V engine.
the best thing to do is to mount the 02A Gearbox from passat etc.
Golf is the shit!
Amit
Amit
Amit said
my pressure plate is bolted on with some star shaped bolts
Amit
On the ABF??? Are they 12 spline? Are the bolts male or female head? If the bolts are female head 12 spline, then the tool is probably an M10 12 spline tool, to undo them. My VR6 had the same, (bolting the flywheel to the crank).
Amit
Amit
Hope this helps.
And i've opted for the lightened flywheel and uprated clutch option with a diesel gearbox (which i already had)
Lets hope it stands up to the 16v.
