Brake lines to pressure regulator???
(In Topic #135187)
I put the question out here too!..
It is so that I have some questions about how to draw the brake lines from my 4 outlet m/c to my brake pressure regulator?
The brake lines were removed when I got my -79 1,6 gti so I dont have anything to compared whit how its was fitted before.
And i also have a mastercylinder and 9" servo from a 16v mk2.
I had thought some thing like this from the cylinder:
1: Left front.
2: Right front.
Then I get a bit confused .. should No. 3 from the mastercylinder go to No. 2 on the brakeregulator? and No. 4 from the mastercylinder to No. 4 on the brakeregulator??
(borrowed picture, let me know if I should remove it)
If i should go after this picture, it`s the right way to go that I just described…
http://www.wagenstad.com/index.php?modid=167&page=6-76-00
But many seems to have made it in other ways, such as my borrowed picture above?
And heres one more way which is not consistent with the way above?
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=61255&highlight=compensator
So how do i do it?
Thanks in advance!
/Tommy
Golf 1,6 GTI 1979
/ Tommy
Golf 1,6 GTI 1979
the 2 pointing in are inlets from the MC the 2 pointing out go to the back brakes
there is a pic on my build thread where you can see the casted arrows
Golf 1,6 GTI 1979
Also does anyone know which outlet on the rear compensator corresponds with which inlet as you would need to know this to ensure you plumbed it to keep the diagonal circuits correct.
as for plumbing im pretty sure the in and out ports are next to each other but its been years since i binned mine. could always blow thru it
daniboy123 said
Thats probably what ill end up doing im away with with work just now so cant get my hands on it at the moment, if anyone knows feel free to shout up!
Did you ever identify which inlet goes to which outlet on the compensator?
