best gear selector cable length
need some advice what gear  selectors people are using in there mk1. ive currently have a carrodo g60 selector and its horrible plus the cable length are way to long. ive got my self a 02j tower with audi tt short shift onto a 02a box, but now looking for a better selector with the right cable length. ive been looking at the polo selectors but dont know if cables will be to short. mk4 cables are longer than the carrodo ones. any info please thanks
I'm still massively undecided on how to run mine.
I've got full 02a setup with corrado cables and shifter, I'm swaying toward just mounting it in the car and running cables thought the firewall. I had a mk2 VR that was using  full 02a and I liked it.
I've also got 02j shifter but no tower yet, as a backup option. Alot of peeps suggest this setup with lupo cables.
corrodo cables are way to long i got my mounted ontop and a hole in firewall. i had to bend them  to fit into bracket and now the shift is so hard to put into gear. i might get a complete lupo shifter with cables and see if its ok or a vw touran
Where abouts do your cables go through the firewall just out of interest?
first i had them just behind the turbo now i got them via the passanger footwell
Strange, i've heard of lots of people doing this without a hitch.
Food for thought…. I'm leaving all this to the last possible point as still undecided.
ok so i went to my local breakers yard and found a polo 1.4 16v on a 54 plate removed the gear selector. trial fitted on my car and the cables are pefect length when running via firewall. no kinks or bends they are shorter than the mk4 golf cables. also grabbed a mk4 02j gearbox bracket while i was there :). just got to buy audi tt short shift and the relay as a bonus they come with the later style ends
Mine has Lupo GTI cables
Cheers,
Ade
i tyred to find a lupo in breakers but no go as i read they work well with fitment . so for 15 quid i took gamble with polo shifter  and it paid off :)
more detail then dude?
Still running through the firewall?
02J selector or 02A?
What year Polo?
FEEEED MEEEE.  :mrgreen:
i trailed fitted all seem good going to fit it propley weekend will take as much pitcures as i go along
54 reg polo 1.4 16v
running cables via firewall
02j selector with audi tt short shift and new relay both  cost 47 quid in total from audi and you get the new ball end types
audi tt short shift part no  8N0 711 046
relay lever part number 1J0 711 202P
Good work, keep us posted dude.
Cheers!
How did you get on with this any pictures as i'm about to do this would be handy but i'm using a mk4 shifter and not sure to run cables under or cut hole in fire wall????
mk4 cables are long .about the same lenght as the carrodo 02a shifter. i tryed to run them via the firewall and they were way to long. i didnt want to run cables underneath as im going big exhaust. hence why i used the polo shifter and cables nice perfect fit when going via firewll. if you got the mk4 shifter run it under the car as they be fine. i get some pitcures up when i get my car back from body shop
Ok mate cheers
I found corrado one's worked perfectly on mine through the bulkhead but i made myself a tower for the shifter mech so that might account for me needing the extra lenght .
Racing is life . Anything before or after is just waiting - Steve McQueen
i know this an old thread, but i am trying to decide way forward at mo.
i have std 83 mk1 gti 020 box with cable clutch and rod shift.
going abf in new year. i have the 02a dpa abf box, but it has hydraulic clutch and cable shift as it came with the engine.
does the cable gear selector fit under the tunnel? polo or mk3. i'd like to keep the interior looking std. what cables should i use? polo or mk3/4. i've heard the mk4 cable shifter is better than mk3, but got no evidence..
any advice from those in the know would be awesome.
thanks
if you want it to looking std. get the mk4 shifter and fit underneath the tunnel. but you would need to change the tower from a 02j to your 02a box. i had the mk3 shifter and tower and was not inpressed hence why i changed my set up to 02j tower in 02a gearbox and later stlye cables
Thanks peterg60
What cars are the 02j boxes on? I'll have to pop to the breakers.
I'll look for the mk4 cable shifter.
How does the 02a with 02j tower and cable shift feel compared to a rod shift mechanism?
Mk4 golf , bora,a3 a lot of of 02j boxes. I'm running a 02a mk3 16v CDs gearbox with a 02j tower and a Audi Tt short shift fitted on tower . It's like a brand new car . A bit mad as a 30yr old mk1 feels so new with gearchange
