2.0 in my cab?
2.0 in my cab?
hey guys, was readin loads o stuff on conversions in the forum and a popular one seems to be using the mk3 2.0gti bottom end with the 1.8 head and k-jet.
I have the 1600 gti running k-jet, can i still do this conversion, will i be able to use my head? and can i keep the same k-jet system? cheers dudes
No on the head its gotta be one off an 1800cc lump (DX PB) , yes you can run k jet but you may need to use 1800 inlet and exhaust manifolds , you'll also need 3 conversion pieces one for the dizzy , 1 breather bung and a flat plate to cover the hole in the block where your cpr sits . to get the best from this conversion you really need to use a ported and polished big valve head .
Racing is life . Anything before or after is just waiting - Steve McQueen
My first post chaps be gentle, we've got a family golf gti i've got my hands on, but needs a new bottom end. its an 1800 so i could use a 2l bottom end??? do they mate straight up? was the conversion parts above just for a 1600, is there anywhere i can read about this conversion, sorry for all the questions, thanks in advance  :D
ie been doing alot of research on this im using the passat 2litre bottom end engine code 2E and im using the 1800 cylinder head ported n polished non GTi carb model, yes u can just use the bottom end and mate it up to ur head, u use the head gasket to match the head, not sure about the belt so if anyone knows what belt to use then please dont be shy msg me ;)
hope this helps.
p.s. if ur using a second hand bottom end, u may aswell do the piston rings and crank bearings whilst ur there, this is what im doing as i dont fancy ripping it all apart 2000miles down the road to replace them.
i always have the last laugh ;)
http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg
<a href="
You'll need the 2.0l cam belt  :wink:
head differencs
so whats the diff bettween my 1600 head and the 1800 head, surely they r the same if not very similar? also can i run it of my 1600 k-jet system or will i need 1800 stuff? cheers dudes
