mk1 How to fix top armrest clip
DIY of how to fix upper armrest mount
I was recently looking around for new clips for the upper part of my armrests, turns out they stopped making the clips and you can no longer get them, so i decided to make my own and since i couldn't find any DIYs i decided to make one.
first off I removed the door panel 1148 views (3 Mb)
1175 views (3 Mb)
1015 views (2 Mb)
I then found a washer to use that would act as my original clip, which is a 5mmx20mm washer 1427 views (1.35 Mb)
I then drilled a notch in the washer so that the door handle fit and would lock when rotated  949 views (3 Mb)
1045 views (2 Mb)
1472 views (2 Mb)
I then tack welded my washer in place, used a grinder on it, and painted it (i suck at welding), not my armrest is as good as new and stronger! 1394 views (3 Mb)
1176 views (2 Mb)
1016 views (2 Mb)
On the drive
Myvalver 89 GTi Grey mk2 16v
