Lights left on warning buzzer with genuine parts
Bought one from ebay for £11. Perfect because i am terrible for leaving mine on!! Great thread
Got my 292 today, fitted it but nothing.
Any help gratefully received.
1983 MK1 Golf four door 1.8T 20V BAM remapped, MK2 dash and loom, TMI interior. daily.
2014 VW California 5.1 with full Sportline kit, weekend home.
Try leaving for fan blower on 1,2 or 3.
Nope that didn't help
Is there a way of testing the relay? I've got a Skoda Fabia MK1 but don't want to go to the agro of getting to the relay panel as it's a PITA and then find it's not the same anyway.
Can I put 12v on it and test it like that, I got if from Stevens VW Dismantle and it has a signature on it (as does the fog light switch I purchased at the same time) so guessing they've tested it.
When should the relay buzz? Is it key out of ignition or just turn the engine off?
Last edit: by Pete M
Of no help but I get the same results!
Sent from my Smartphone
Not sure on how to test it, but mine buzzes when the lights are on and you switch the ignition off with the key in. The buzzer also sounds if no keys in and you just turn the lights on.
Perhaps it's something to do with the change of fuse box which your car has???
Mmm maybe but it's just a OE CE2 fuse box and loom from a 91 MK2, as far as I read it that should work with position 7 .
I had the same it didnt work, so just left it in. Today i was removing the binnacle and clocks, accidently pushed my wiper up with the ignition off and the warning buzzer came on! So it does work, but will only warn you if you left your lights on if it has been raining! Any thoughts??
So it works with the wiper lever up or down but not in off…
Adam
Adam
You have to make sure all your lights are working and no blown bulbs. My friend copied my idea but it did not buzz at all. Strangely enough once changing the bulb in the headlight switch it burst into life.
The headlight switch has a little bulb that's on constantly when the car is on or running so you can see your switch in the dark when you need to put your lights on.
Try this, if not check fuses and for wiring faults. If all else fails try a replacement fuse box
I know i suprise myself sometimes with my geniusness ness
Adam
Same here!! Any help?
Ok, so I had one in the garage for 20 years… Today, I thought I'd seize the moment.
Two minutes later, I revelled in my success.
Thanks!
Thanks!
92 Fashion Line cabby (New Girlfriend )
89 Black Clipper Auto (Lost)
83 Black GTI Engineering Resto - (Minty!)
05 PD Passat daily driver (unbreakable)
Thanks for the tip - ordered one from Lithuania, getting expensive - £28
I got me a 1987 GTI Cabriolet - Quartet in White/Blue/Blue
