Valve springs
(In Topic #234306)
I’m currently restoring an 83 gti that’s been in a barn for just shy of 20 years.
I’m rebuilding the head at the moment but cannot find valve springs anywhere! If any one has a set or can point me in the right direction I’d be very grateful.
Also any other tips or advice would be great as this is my first mk1 and first time going this deep into a resto.
This is the current state…… excuse the ducting… previous tenants in my lock up were umm… keen horticulturists!
Dom
Regional Host NE
Valve springs
1.8GTI 8v DX
Regional Host NE
Valve springs
Had head pressure tested, skimmed and new valves lapped in. Have valve stem oil seals just need all inner and outer springs to reassemble
Regional Host NE
Re: Valve springs
See what i have mateGilbertdfx said
Yeah I was planning on re using collets and top and bottom spring cup / caps.
Sent from my SM-G960F using Tapatalk
Valve springs
The engine in my car is actually an EV. Which from reading on here is identical to the DX apart from a vac port on the head…..?
I have now found springs that will fit a DX so does that mean they will fit the EV head I have? I have part numbers for the springs but nothing to compare that to and cannot find that info online.
Just need to know if dx valve springs will fit an ev head basically.
Dom
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=big-block-injection_2%2Fev-engine-code_2
mark1gls said
Bit more info on the EV engine code.
Thank you!!
