Are Low Oil Pressure sensors of different types interchangeable?
(In Topic #208807)
I have newly aquired a 1991 Clipper, so this is my first post. I understand that the low oil pressure sensor on the 1.8 is the one on the side of the head?
I have called Euro Carparts to get a replacement and the one they sent is different to the one fitted.
The one fitted is a screw in plug with a single wire tagh on it. The one they sent is like a small canister with two tags on the top. I assume one tag runs an oil pressure guage which I havent got. Does that matter? Can i use it anyway with just one side connected?
Thanks All.
There are a list of senders at www.cabby-info.com.
The last one that I bought was a pricey item, and it wasn't the correct BAR setting and kept giving erronious readings. I ended up having to move it to the oil filter flange.
Send it back and get a sensor which looks the same as yours.
The colour of the sensor is also important, blue/black for the sensor on the side of the head and white for the sensor above the oil filter.
The sensors sometimes have the info stamped into the side of them.
Mk1 golf cabriolet was in production along side the Mk2 golf so that is why the confusion happens.
