Rings and bearings help
(In Topic #236041)
I replaced rings and bearings on my golf now it wont start van anyone give me advice please
Set your valve timing to the book then the ignition, line the rotor arm up with the notch on the case, then if it should start use a strobe.
Is there a spark at the plugs?
The engine needs fuel, air and a spark at the right time so start at the basics and check everything over.
ght up
Was the timing 180 degrees out?
