ABF MK1 GTi will not start, no spark
(In Topic #222069)
Any help or suggestions will be gratefully received.
On the drive
Myvalver 89 GTi Grey mk2 16v
Edited to add Rubjohnny. That's twice, once more and a hop on one leg right?
get diagnostics sorted, its dead easy so long as you at least ran the grey/white diagnostic wire inside the car from ecu pin 43. if so, you get yourself a 16 pin plug from just about anything 1996 onwards. connect grey/white to pin 7, give it live to pin 16 and earth to pin 4.
then you can check to see if the ecu is even powering up right, look at engine rpm measuring block to see if its seeing a signal from crank sensor etc
