Golf Mk1 Door is locked closed.
(In Topic #221938)
I need help unlocking the door without using the handles
Depending on the year you may be able to insert a wire coat hanger in to the window channel between the scraper seal and the glass reach for and pull up on the lock mechanism from the outside. Here is how the wire should look, as it allows you to Push on a latch or Pull on it when I worked on old adding machines we called it a push spring hook.
If you are on the inside can you open the door and unlock it?
You want to grab the upper finger on the left (inside) for the lock, and the one on the out side you push down to open.
Last edit: by Briano1234
You can usually see this on the striker pin as the nylon ring is damaged or missing.
Tin tops you don't notice the sag as much as the window is in a frame, but the Cabriolets are more noticeable.
You can re-align them with the use of a washer that is cut to go between the hinge.
Saggy Door Fix | Volkswagen Owners Club Forum
Now fixing a saggy door is but one step, the other is that you may have to re-align your window glass to the seals as the previous owner may have adjusted them… I have how do I do that's in the archive section.
To keep the doors from sagging, don't put your weight on them to get in and out of the car…..
