Leak from top drivers window
(In Topic #215695)
I have a leak coming through on my cabby. It seems to be seeping through above the drivers side top window seal.
I have changed the rubber seal three times, also put foam in the rubber seal, changed the frame above on the roof for a flatter version, adjusted the window higher and the door as was previously sagging. Also I should mention the roof sits pretty tight.
Now I'm completely clueless.
I'm thinking of putting a thin coat of black silicone. Does anyone have any other ideas? I saw Briano1234 link and he applied a silicon Permatex Black Ultra RTV which I'm thinking of buying. I have attached a picture you can see the water seeping through above the rubber seal
make sure that your "a" pillar seal is over the vent wing finger seal.
If you have a saggy door fix it.
After you fix it it may still need to have the glass adjusted.
All I know about leaking tops.
Convertible Top
Cheaper Rear Cable (cost effective)
http://volkswagenownersclub.com/vw/showthread.php/99266-Cheaper-Rear-Cable.
Top frame Seals:
http://volkswagenownersclub.com/vw/showthread.php/80306-Convertible-Top-Frame-Seals?p=605050#post605050
Replacing your Top, that pesky rear cable.
http://volkswagenownersclub.com/vw/showthread.php/89706-Replacing-your-top-that-pesky-rear-cable.?p=638234#post638234
Top Boot Cover Strap Upgrade.
http://www.toplessrabbit.com/forums/viewtopic.php?f=41&t=3271
Rear Cable that I can endorse.
http://www.toplessrabbit.com/forums/viewtopic.php?f=41&t=3012
Rear Cable Lubricant for Cloth tops.
http://www.toplessrabbit.com/forums/viewtopic.php?f=41&t=3208
How I install convertible tops.
http://volkswagenownersclub.com/vw/showthread.php/32262-Cabriolet-Convertible-Top-Installation
Installing your top padding kit.
http://volkswagenownersclub.com/vw/showthread.php/32182-Cabriolet-Top-Pad-Installation
Installing your head liner.
http://www.toplessrabbit.com/forums/viewtopic.php?f=41&t=3013
Replacing your rear window.
http://volkswagenownersclub.com/vw/showthread.php/57770-Cabriolet-Rear-Window-Replacement.?p=519466#post519466
How to make your own rain gutters.
http://volkswagenownersclub.com/vw/showthread.php/32177-Make-your-own-Vert-rain-gutters
"A" pillar gap repair.
http://volkswagenownersclub.com/vw/showthread.php/32474-Cabriolet-quot-A-quot-pillar-repair-the-Gap.
Wind Noise at the leading edge.
http://volkswagenownersclub.com/vw/showthread.php/95882-Leading-Edge-Wind-noise-and-your-top.?p=655074#post655074
How to clean your "A" pillar seal.
http://volkswagenownersclub.com/vw/showthread.php/32218-Cabriolet-How-to-clean-your-quot-A-quot-pillar-Seal
Cabriolet top pad measurements.
http://volkswagenownersclub.com/vw/showthread.php/32194-Cabriolet-Top-Pad-Measurements
Ez-on top replacement instructions.
http://volkswagenownersclub.com/vw/showthread.php/32193-EZ-on-Cabriolet-Top-Installation
"A" pillar door seal repair, stop the drip.
http://volkswagenownersclub.com/vw/showthread.php/32192-Cabriolet-quot-A-quot-Pillar-Door-Seal
Where to oil your top frame.
http://volkswagenownersclub.com/vw/showthread.php/32191-Cabriolet-Top-Frame-Oil-Points
Cheaper replacement top struts.
http://volkswagenownersclub.com/vw/showthread.php/32190-Cabriolet-Cheaper-Top-Strut-Replacements
Top latch removal
http://volkswagenownersclub.com/vw/showthread.php/32189-Cabriolet-Top-Latch-removal
Make your own rear cable.
http://volkswagenownersclub.com/vw/showthread.php/32181-Cabriolet-DIY-rear-cable
Improve and make your own side tension cables.
http://volkswagenownersclub.com/vw/showthread.php/32180-Cabriolet-DIY-side-tension-cables
Leaky Car Syndrome fixes:
Another Leaky Knee Fix.
http://www.toplessrabbit.com/forums/viewtopic.php?f=41&t=2737
Swimming Pool in Front Seats.
http://www.toplessrabbit.com/forums/viewtopic.php?f=41&t=2853
Where is my top leaking.
http://www.toplessrabbit.com/forums/viewtopic.php?f=41&t=2655
Where is my trunk leaking.
http://volkswagenownersclub.com/vw/showthread.php/32207-Cabriolet-mk1-Where-is-my-Trunk-Leaking
Why are my feet Getting wet, all I did was change the antenna.(Drip Stop Loop)
http://volkswagenownersclub.com/vw/showthread.php/108841-Why-is-it-raining-on-my-feet-I-just-changed-the-antenna…..
The following link doesn't work…
Top frame Seals:
This is where the leak is seeping through just above the rubber seal.
I've ordered Permatex Black Ultra RTV, as I feel if I apply one coat in the inside and outside this should block the flow of the rain coming in to the car….
Briano1234 said
Thank you!
Do you think if I apply a coat of Permatex Black Ultra RTV this will block the drops from seeping through Briano1234 ?
There is also the J-hook seal that the gap between the frame mating to the receiver can leak,
Look through all the leak fixes I mention,,, One is sure to stop the flow.
Briano1234 I've applied a layer of sealant and will judge how it goes. However I do need to do the a pillars as it doesn't overlap but I had to do a tactical retreat as the weather is so cold over here in the UK lol
I also noticed I have a gap between the b pillar and the top window seal (see picture) although the surprisingly water doesnt seep through here but when I'm driving the wind infiltrates through this space. Any idea what I could do to sort this out?
but the foam end caps are the bees knees.
https://www.vwheritage.com/155871419-centre-weather-strip-seal-for-roof-mechanism-golf-cab-86-93
1 on each end so for the sides I think you need at least 4/side
I had the same problem when replacing my roof and I just pushed them closer together.
On my hood there was a real sewn joint between the middle and side sections, to waterproof this area a strip of material had been glued along the inside. On mine the glue had given up so it leaked, a new strip glued in place probably would have fixed it but I ended up with a new hood which was in better condition, this one had a fake moulded joint rather than a sewn one so no leaks possible
as above with the seal gap, its just a case of replace the foam pads on the ends of the metal strips then carefully pull either end of the rubber outwards from the metal carrier seal till the gap closes up. As Mark said theres a little plastic clip, this time of year it'll be extra cold and brittle so be very, very careful!
