Treating rust?
(In Topic #228221)
Any feedback would be appreciated. Thanks
check if rust is coming through paint from outside in or inside out…
1 Rub the area down with emerytape/grinder.
2 Treat area with some rust treatment liquid as instructions.
3 Add zinc primer(helps prevent rust) and then prep for repainting.
4 Paint.
www.kennysclassiccars.co.uk @ https://www.facebook.com/serviceandrepair.co.uk/
On the drive
Myvalver 89 GTi Grey mk2 16v
I usually grind, or sand, use a rust convertor, prime (depends on what type of metal, If I use Zinc…) then prime again, do body work if needed, then paint smooth, and clear.
On the drive
Regional Host NE
If it's surface rust, creeping under the paint from the outside, it would have been caused by historical damage to the paint which exposed the metal, such as a scratch or a stone chip. Your pointy thing will not go through it no matter how hard you poke it. This sort of rust needs sanding/grinding out, followed by sanding, feather edging the paintwork around it.
Then you can treat any pitted areas with a rust converter, followed by a full paint refinish process, involving a respray of the complete panel.
Hope this helps 👍🏽
