TRACK ROD END
(In Topic #209824)
removing track rod end
Thanks.
picture would be helpful?
If its removal of the ball joint from the shaft it should have a milled section where you can put a spanner - a good tip is to break the connection when its in one piece.
Do it once and do it right! ok, we've identified the problem, lets not make it worse by guessing……… Identifying the sympton is not the same as understanding the cause
If no play then I would leave it alone, you have a factory fit none adjustable track rod so to change the end you have to change the whole track rod and fit a new end.
Read this. Pictures at the start of the thread and lots of info..
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=helllllpppp%2Floose-axel&=#post_1558443
Good luck
Lee
2001 Zafira 1.8
2001 Zafira 1.8
If not then you need to keep looking
