Tie rod removal
(In Topic #217213)
Access
Access seems restricted even when i turn the steering wheel and can't seem to be able to get a wrench in from any angle.
Have also read one of them has a left hand thread but vwh told me and sold me 2 tie rods exactly the same.
Also the chap who tried to do my tracking mentioned that one of them was a fixed type and couldnt be adjusted anyway.
Any pointers gladly received.
1990 Golf GTI cabrio 1.8i. DX Engine
I guess it all depends on where your locking nut is as I could not get a spanner on my locking nut.
I just moved the steering rack about till I could just about get my hands in.
Something like this.
https://www.ebay.co.uk/itm/Neilsen-Slip-Joint-Plier-Water-Pump-10-Groove-Joint-Adjustable-Head-Steel-8B/370718278363?epid=16004178212&hash=item56508802db:g:y4QAAMXQydtTNDhK
The none adjustable track rod is the on the passengers side, if you are replacing it you will need a new track rod and new track rod end, you should be able to see the difference in the track rods.
Fit some new track rod boots and re-grease the steering rack while you have it all apart. Also good time to centralized your steering rack so you have the same amount of turns from straight ahead to lock to lock, you may need to remove the steering wheel to get is straight then get the tracking set up.
Last edit: by mark1gls
That is how I have done it. You can possible get a wrench on it from underneath.
You can take the one piece off, and use the two pieces inner and outer, and I thought that all the later cabriolets used the 2 piece rods but I too have had a fellow tell me that they where a one-piece rod, and that the Camber wasn't adjustable… I took my car from there, and found another shop that really wanted my business.
Over here you can still get the one piece rods, but the last time I ordered one it was 2-piece.
They list in the parts as inner or outer. If the inners are bad then you can get separate inners and outers which makes it more bearable in the future just make sure that you use Never-Seize on them including the outer shaft.
Makes changing them a whole lot easier and your alignment guy will love you for it.
Thanks again.
Try not to move the locking nut on the steering rack to far away from where it was so you know how far to screw in the new track rod.
Passenger side was a fixed tie rod and not a left handed thread in sight.
Anyway, quite a fiddly job but another one to cross off the list. Booked her in for a 4 wheel alignment Thursday so happy days.
Thanks mark1gls and briano123 for the input.
Always happy to help if I can.
