Thermo time switch multimeter test
(In Topic #222549)
I have a thermo-time switch I suspect might be faulty. The engine is not yet mounted, and I'd like to verify if it's a bad one before I start it. Does anyone know what the ohm-readings should be at the W and G terminal?
The only measure I am able to get is from the TTS body to the G, which is around 67 ohm, warm or freezing. From the body to W and between G and W there is no reading/open circuit. The TTS also rattles like a broken incandescent bulb, so something seems quite loose inside it. Don't know if that's normal. Any input appreciated.
Early 77 year model Golf. 4-Door
but the fact it rattles tells me its probably knackered, cant say I've ever heard one do that
if you make up a test circuit say with a lamp and battery, the bulb should light up if you run circuit via the W and casing. if you put 12v between the G terminal and casing after a while W should go open circuit
_ v _
w ..g
notch on top, w is on left g on right
g to ground is …..
under 86F/30C* 25-40 ohms
over 104F/40C* is 50-80 ohms
w to ground is
under 86F/30C* 0 ohms
over 104F/40C* 100-160 ohms
w to g is
over 104F/40C* 50-80 ohms
Last edit: by goldie_88
