Tap / knocking sound
(In Topic #220413)
Guest user
MK1 golf 1.8t tapping - YouTube
I was pretty sure I kept the timing correct when I changed the belts but I am a beginner when it comes to engines so I'm really worried it's that. It does sound like it's coming from a single place though rather than right across the engine. More on the passenger side.
If any one has any ideas or suggestions that would be amazing.
Cheers,
Adam
Guest user
I'd replaced the belt while the engine was out and by some huge stroke of luck, everything is easily accessible with the engine still in so it was't a big job to sort out
Diesels are a Different Critter if you are 2 teeth out, major ca-ca-will-occur.
Guest user
I'll be doing a compression test at some point soon to fully rule out any bent valves
