Tail light problem
(In Topic #222618)
Only one working!
On the drive
Myvalver 89 GTi Grey mk2 16v
wire colours for front & rear sidelights are grey/black and grey/red. most common places for damage is where people can get at it for bodgery, so at the fusebox and in the boot. usually the runs under the carpet will be ok
The Seals on the lenses can distort and leak water which can fill the lenses with H2O and they can corrode and make crrrrrappy connections…. It was so bad after one of my in-laws replaced it with the wrong wattage, and the wifes 700+ mile drive back home, the lense cracked and melted a wee bit….
If it does share the Brake as it is dual filament, then I would ask if the Brake part of the bulb works, and if it doesn't then you may look at the ground first.
I have also seen where you can force a dual element bulb backwards in the socket and it doesn't work either.
Harrison93 said
found The issue! Pulled the plug for the rear loom from the back of the fuse box off to find terminals gone green from water ingress. sprayed up with electrical cleaner and cleaned the terminals and it's now working! Now to replaced my windscreen seal. cheers again guys
If it isn't one thing, it's another . so goes the mk1 ownership blues.
