Struggling to start
(In Topic #219981)
So last week I fitted a new battery to my car and it fired up on the button, I went out for a couple of hours in my car as it’s not been driven for a while. I pulled up at the petrol station to fill up and when I got back in the car and tried to start it it started to struggle, it sounded like the battery was going flat.
Now I’m not clued up really on these I just enjoy driving them, could this mean that my alternator is knackered and needs renewing?
When the engines running put a multi meter set at 20v on the positive and earth terminals and you should be getting 13.5 - 14v.
Anything less than this means the alternator isn't the best.
Check the earth straps from the battery to the chassis leg under the battery and onto the gearbox. Make sure they are in good condition.
If it was a new battery it may just have been a little undercharged and had enough juice for the first start and then if it was only a shirt trip to the petrol station it wouldn't have enough time to put a good charge in the battery.
Give her a good run if you can for about 30 mins without stopping, ideally a dual carriageway or similar, assuming the alternator is fine.
Ian
Struggling to start
Personally I would spend money on a replacement as I like shiny parts.
Also and don’t want to be rude but makes sure you tightened up the battery clamps. You say you don’t know much and I know this is habit for most but just In case as it can save you ££££
If the regulator has very short bushes or is rather rusty connections get a new regulator, it's a lot cheaper then an new alternator and 9 times out of 10 its worn bushes that causes low voltage front the alternator.
https://www.ebay.co.uk/itm/New-Genuine-MEYLE-Alternator-Regulator-014-731-1023-MK1-Top-German-Quality/202139560191?fits=Car+Make%3AVW&epid=249168218&hash=item2f1074e8ff:m:m-BHsZt2b1bKOrzQwstYl-A
Struggling to start
Thanks again
Struggling to start
Dazrogers91 said
Checked the voltage on the alternator and it’s showing between 13 and 14v, could it possibly be the battery not strong enough to start the car?
Yes, and or the Starter is old and or the bushing is Binding the starter from spinning due to dirt/goo/and such.
