Steering column moves with clutch
(In Topic #233486)
I'm thinking that the tube the steering column goes through has somehow broken, which I think is attached the the clutch pedal?
I can only see upgraded pedal boxes available on the internet, and not sure what can be done here. Any advice would be welcome, thanks
you can get a repair patch to strengthen this area. some are stick on and others welded.
https://www.heritagepartscentre.com/uk/171898152-bulkhead-repair-patch-for-the-clutch-cable.html?gclid=EAIaIQobChMIu4Wr79CS8gIV1PhRCh0LnwFVEAQYASABEgJsdPD_BwE
Regional Host NE
Re:
Would not think the area around the clutch bulkhead area would affect the steering column unless the whole bulkhead is shot picture would be goodtnotty said
It's quite common for the bulkhead to give way where the clutch cable goes through. I suspect this may have happened and is flexing the metal around the bulkhead which is moving the column. Have a look up under the dash and you should see where the clutch goes through.
Sent from my SM-G960F using Tapatalk
