Starting issues on 1982 1.6 GTI
(In Topic #220435)
Sent from my SM-J510FN using Tapatalk
Turned out to be some split var hose on the inlet manifold and badly adjusted timing to compensate for it. Was running really advanced. It is now a little too retarded but having a new 4 branch fitted next month so will wait to time wants that is fitted.
If you are losing pressure then it could be the injectors are dribbling and flooding the engine hence it splutters and hunts when it does finally start as the excess fuel is burnt.
I think I'm right in saying that with a loss from anywhere else the problem will be not enough fuel and the engine will run almost perfectly when pressure is built up although there could be vapour in the lines if the car is hot.
One thing you could try is warming it up until it reaches the point where it struggles to start, turn it off, leave it for a few minutes then start it up and when it starts turn it off and have a look at the plugs, if they're wet and a bit sooty you have too much fuel, pale and dry not enough.
If you google 'Bosch K-jet fuel pressure gauge' something should come up.
If you're near Falmouth I'll have a quick look at it for you.
I swapped the fuel pump,relay for a no 17 one which runs the fuel pump constantly when ignition is turned on, not just a quick priming boost. I had no problem afterwards.
This does cause an issue though if you have an accident as fuel pump wont cut out. If the problem persists with the original relay goes in after my engine rebuild, i am going to revert back to the no 17 relay and get a fuel cut off inertia switch off a modern car installed.
Re:
What would be the best way to depressurise the system I have made a couple of spade connectors with a inline fuse to get the pump to run constant without starting the car, so basically I have to depressurise the system, add the gauge between the fuel distributor and WUR and the keep my pump running , then switch off the pump and see how long it holds pressure ? Am I correct ?cedar said
The gauge goes in line between the fuel distributor and the WUR, you have to de-pressurise the system to fit it and ideally have a means of running the fuel pump without starting the engine. I've just got an old fuel pump relay with a heavy length of flexy cable soldered to the large spades on the relay with a switch on the other end, it works okay.
To do a holding pressure you have to run the engine until warm with the gauge connected and tap open and then turn the engine off, wait for ten minutes or so and check the pressure which should be above a certain limit which you will have to look up, I seem to remember the Haynes manual covers the 1.6.
I'm not sure of the 'book' way to de-pressurise but I just left the car overnight and then fitted the gauge in the morning before starting it with some rags to soak up any petrol that escaped with residual pressure, probably not the way a Bosch agent would do it though.
Remember you're working close to the battery so if you have a go be really careful, cover it well. Years ago when I was looking for a Mk1 GTI I went to sae a 1.6 for sale that had been set on fire, not sure what happened but it was a real mess around that area, at the time there were plenty of spares in the breakers but I didn't realise that and didn't buy it, they only wanted £100 or so for it.
The fuel boils in the lines under the hot engine bay if its not under pressure hence the poor hot start. On both my GTI's you can hear the accumulator spring "ping" as it slowly loses pressure over 20 minutes or so.
You could try cracking one of the fuel filter banjos after 10 minutes to see what pressures in there but be careful as if its still highly pressurised it will spray a good amount of fuel over everywhere. If it doesn't then there's your problem. The system pressure is around 70psi after switch off and should take a minimum of 20 minutes to lose the majority of its pressure to give you an idea. As I said be careful with this method!!
K-Jet Fuel Pressure Testing - YouTube
