Starter Motor - clarity on which one
(In Topic #221634)
Please can someone confirm the right starter motor for my '92 GTI Sportline cabby?
Thank you
Adam
Why, because there are 2 starters for automatics and putting the wrong one on can ruin the flex plate.
While all 92's should have a spoked flex plate that isn't to say is hasn't been changed to a solid pre-85 flex plate.
The Solid flex plate starter will not work with a spoked fles and Vice-versa.
To differentiate there are 3 protrusions in the starter mount on the Bendix side, you can't see them until you have the starter out… If you see spokes with holes as you rotate it then it is a spoked wheel, that is you can see the torque convertor.
If you can't see the torque convertor then you have a Solid flex plate.
The Solid flex plate starter looks like this.
The yellow circles are were the protrusions are on the spoked flex.. Solid flexures like this one don't have them.
Yes Solid flex starter.
Spoked flex plate.
Solid Flex plate.
Manual 1.8 dx
You can jack the car up and place on stands.
From the bottom of the bell housing you can view the flex plate.
If the bolts that hold the Torque Coverter have 2 rivets on each side it is usually a spoked.
In the thread or post above you can see which plate you have.
Spoked starters will work on solids, but solids won't work on spoked.
