standard coil spring size
(In Topic #232276)
1300 driver standard front coil size needed
spring on a 1300 driver tin top .. length, diameter and coil thickness if possible?
got coming back from painters soon but doesnt sit right on front looks too high
changed ages ago with new shocks and springs , but only just put back on after about
3 years sat on drive.
regards
Adrian
Ade
https://www.heritagepartscentre.com/au/171512333-rear-shock-absorber-top-mount-lower-bush.html
Sorry can't help with size of springs but looking at pictures of this one with the standard size steel wheels you could easily get your fist in between the tyre and wheel arch.
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=cars-for-sale_2%2Fsilver-mk1-golf-driver
Regional Host NE
Fitting Position Rear Axle
Parameter AA
Spring Design Coil Spring
Weight [kg] 1,88 kg
Thickness 1 [mm] 10 mm
Outer diameter [mm] 98 mm
Length [mm] 348 mm
Parameter AA
Weight [kg] 1,88 kg
Length [mm] 348 mm
Blimey paul , thats impressive but do you have the compression weight for the spring, and the test jig? Maybe just gone soft…
Any how…. advice is always change both springs, and rubbers then geometry should be equal.
When changed to coilover ive dropped 20 to 30mm across both axels, to give modern look. As mark1gls says original cars have high clearance set up, also small wheels 13 and 14"
On the drive
Myvalver 89 GTi Grey mk2 16v
Have replaced all bushes, bearings etc, when car
Comes back will take off springs and compare sizes
With standard .
Ade
Ade
